2. Jacket fatigue analysis - Tính toán mỏi cho kết cấu chân đế
    Dear các pro,
    Mong AE cùng chấp bút để hoàn thiện topic này.
    Gửi ACE scope những phần việc của bài toán này trước, sau đó củ từ giải quyết vấn đề.
    Scope of document:
    The report presents the dynamic spectral fatigue analysis carried out for the detail engineering of the Jacket. The analysis approach is performed in accordance to AISC Allowable Stress Design, API RP2A – 21[SUP]st[/SUP] Edition, and Substructure Structural Detail Design Basis, using SACS suite programs.
    The objective of the dynamic spectral fatigue analysis is to ensure that the welded tubular joint connections have sufficient capacities to avoid the development of joint fatigue crack leading to joint fatigue value due to cyclic environmental loads, during the design life of the platform. The type of analysis applied is a comprehensive dynamic spectral fatigue analysis in the frequency domain where the dynamic properties of the jacket are modeled.
    A wave scatter diagram as per Appendix that provides statistical distributions of short-term seastates is used to represent the long-term statistic of seastates. Each short-term seastates is described by the sea surface elevation spectrum that gives the energy content as a function of wave frequency.
    The fatigue analysis can be conveniently divided into the following stages:
    · Model generation for stiffness of the structure and foundation
    · Generation of structural mass and mode shapes
    · Generation of the static transfer function
    · Generation of the dynamic transfer function
    · Perform fatigue analysis
    API RP-2A WJ S-N Curve is used for fatigue life calculation for simple T, K and Y tubular joints. The inverse slope of the S-N curve, m, is taken as 3 for N<107, and 5 for N>107 where N is Cycles to Failure.
  3. Khong
    Các bước phân tích mỏi
    Giới thiệu AE 23 bước cơ bản để xác định tuổi thọ mỏi kết cấu chân đế Jacket.
    1, xét hướng sóng chính k=1, (k=1…8). Trong trường hợp không có thống kê sóng cho riêng từng hướng, cần biết xác suất Pk xảy ra sóng theo mỗi hướng
    2, Xét sóng biển thứ i=1, (i=1…I), trong khoảng thời gian thống kê 1 năm. Mỗi sóng này được đặc trưng bằng chiều cao Hi, chu kỳ Ti và số lần sóng ni
    3, Xét một vị trí tương đối giữa đỉnh sóng và kết cấu j=1, (j=1…J)
    4, Tính toán lực sóng theo công thức morison
    5, Tính toán nội lực dọc và các momen uốn
    6, Lặp lại bước 3 cho mọi vị trí sóng
    7, Lặp lại bước 2 cho mọi trường hợp sóng
    8, Lặp lại bước 1 cho mọi hướng sóng chính
    Lưu trữ các kết quả về nội lực ứng với các sóng khác nhau, theo các hướng khác nhau
    9, Xét mối nối cần quan tâm về mỏi l=1, (l=1…L)
    10, Xét mặt phẳng m=1, (m=1…M) trong mối nối đó
    11, Xét ống giằng q=1, (q=1..Q) trong mặt phẳng đang xét, mặt phẳng này gồm 1 ống chủ và Q ống giằng
    12, Phân loại ống giằng đang xét, nó thuộc kiểu X, K hay T…
    13, Tính các hệ số tập trung ứng suất SCF ứng với các thành phần nội lực và ở hai phía chân mối hàn, một ở phía ống chủ và một ở phía ống giằng dang xét
    14, Tính số gia ứng suất cục bộ lớn nhất Sn, ứng với sóng biển thứ i
    15, Tính số chu trình phá huy Ni ứng với Sn từ phương trình đường cong mỏi S-N
    16, Tính tổn thương mỏi ứng với sóng biển thứ i
    17, Tổng theo i, ta được tổn thương mỏi ở hướng k
    18, Tổng theo k, ta được tổn thương mỏi ở chân mối hàn giữa ống chủ và ống giằng q=1
    19, Lập lại từ bước 11) ta được các tổn thương mỏi ở mặt phẳng m=1
    20, Lặp lại từ bước 10), ta được tổn thương mỏi ở mối nối l=1
    21, Lặp lại từ bước 9), ta được tổn thương mỏi ở toàn chân đế
    22, So sánh để xác định tổn thương lớn nhất ở chân đế trong 1 năm: max D1 năm
    23, Tính tuổi thọ mỏi của toàn chân đế: L=[D]/max D1 năm
  4. jacket
    jacket Member
    http://books.google.com.vn/books
    Anh /em ai có file sách này ko? có thể up cho mọi người tham khảo dc ko ạ?
    probabilistic fatigue analysis of fixed offshore structures - J.H. Vugts
  5. real-07
    Probabilistic fatigue analysis of fixed offshore structures - J.H. Vugts
    Tên này với tên ở trang cover của cuốn sách lại khác nhau nhỉ?
    Offshore Technology in Civil Engineering.
    Cách làm:
    Nhờ mấy bạn Sinh viên có nhiều thời gian, chụp hinh màn hình bằng phím Print hoặc phần mềm chụp
    Sau khi có ảnh từng trang sẽ convert thành pdf và combine lại là thành cuốn sách.
    Have fune
  6. hoainam.dhxdhn
    hoainam.dhxdhn Moderators
    File sách em đã chụp và chuyển sang pdf rồi đấy ạ
    http://www.mediafire.com/?ucphu10m12cs0sa
  7. jacket
    jacket Member
    hì hì rất cám ơn tấm lòng nhiệt tình của đồng chí Hoainam! mặc dù ko đầy đủ nhưng quý ở chỗ tấm lòng.
  8. hoangtu
    Hướng dẫn cài đặt S-N curve cho bài toán mỏi
