Sesam GeniE 6.4 có gì mới?
Discussion in 'SESAM/STAD/SAP/ANSYS.' started by SteelMan, Apr 24, 2013.
  1. SteelMan
    Aug 9, 2012
    New version Sesam GeniE improves ease of use and gives better control of data
    This new release is made with the purpose to bring all important modelling in one data model. It will make the work for you as a user easier and at the same time give more control and increased quality. Amongst other improvements we have also improved the import possibilities for old data into Sesam GeniE. As always the improvements of the new version are based on customer feedback. We encourage all users to update to the latest version. Please read the release note documentation before updating.
    Main highlights of the new version:
    Fixed Stuctures
    • Point connection management - Easier and better control
    • Tension-compression analysis – New functionality and precise results
    • Equipment modelling for dynamic/eigenvalue analysis - Full control of load transfer
    • Import model data from Sacs/StaadPro – More complete
    Floating structures
    • Surface modelling – Easier to make a surface
    • Guiding curves - Easier to create
    • Import and export of curves - Support from any CAD system
    The release note can also be found on DNV website.
  2. NoName
    Jul 20, 2012
    Sesam Manager New features Ver 6.01.02:
    • Make file management more transparent and easy to modify by using Pre and Post execute scripts
    • Enhanced funstionalituy of Copy/Move commands
    • Zoom-funstionality in main window
    • Improved functionality for Recent jobs list
    • Search functionality for Sesam Manager jobs
    • Definition of working directory when starting applications from Quick Start
    • Support multi-line script commands
    • Full support for relative paths in import/export
    DNV also incorporated Sesam Manager into Sesam. It will be installed automatically if CLIENT is installing Sesam for the 1[SUP]st[/SUP] time.
  3. Phongba259
    Phongba259 New Member
    Aug 11, 2012
    Mình đang sử dụng phần mềm GniE V6.4 để thiết kế cho giàn BK. Sau khi sử dụng phần mềm này để tính toán và so sánh với kết quả của SESAM (sử dụng công nghệ siêu phần tử) thì thấy có một số ưu, nhược điểm sau:
    - Nếu giàn khoan có cọc lồng trong ống chính không liên kết bằng bơm trám mà liên kết bằng các Spacer thì chức năng "Point connection management" vẫn chưa thể hiện đúng liên kết tại các điểm này.Mình đã sử dụng chức năng "Point connetion management" và thấy kết cấu giàn cứng hơn dẫn tới chu kỳ dao động riêng nhỏ hơn so với sử dụng SESAM.
    - Các phần tử "Tension - Compression Only" thì không chạy được khi có tải trọng sóng.
    - Ta có thể thực hiện code check cọc trong đất với V6-04. Chức năng này có lẽ là tiến bộ nhất. SESAM không có chức năng này. Với các công trình trước đây các chú, các anh tại phòng NIKO khi kiểm tra cọc phải lập bảng Excel để tính. Không biết trong SACS có chức năng này không?
    681
    47
    Cao thủ sử dụng Sesam đây rồi?
    1 - Không hiểu phần mềm Sesam phân biệt như thế nào liên kết giữa cọc và ống chính loại vữa bơm trám (grout) và liên kết spacer? (tức là thao tác hay câu lệnh nào thể hiện việc này)
    Thực tế, ít khi sử dụng grout full length của pile.
    3 – Trong Sacs, việc kiểm tra code check (UC) cho phần cọc ngập trong đất là có, xem hình đính kèm
    Ngoài kiểm tra UC cọc trong giai đoạn in-service cụ thể là bài toán inplace, người ta còn phân tích cọc trong quá trình thi công đóng bằng grlweap, theo đó chiều dầy cọc yêu cầu thường là sẽ lớn hơn so với bài toán inplace.
    Hình 1: kết quả kiểm tra UC phần tử cọc dưới mudline
  5. SteelMan
    Aug 9, 2012
    Cho mình một vài ví dụ phân tích với phân tử với Tension - Compression Only chịu tải trọng sóng, gió và dòng chảy để nghiên cứu xem?
  6. SEASTAR
    Jun 5, 2012
    Theo như bạn Phongba259 nói thì SESAM còn đi sau nhiều so với SACS về GAP (Com/TEN) và PSI (cọc-đất nền). Vậy tại sao có nhiều lời ca tụng về phần mềm này? Tại sao phần mềm SACS giá cao hơn mà vẫn nhiều người dùng hơn? Xin cho vài tính năng vượt trội để mọi người nắm rõ hoặc Admin cho ra lò một topic về so sánh giữa SACS và SESAM về lĩnh vực Structural Analysis :::^^:::
  7. Phongba259
    Aug 11, 2012
    Bên mình trước đây và bây giờ có thiết kế các công trình DK cho Bộ quốc phòng. Công trình này được đặt trên nền san hô chỉ chịu nén chứ không chịu nhổ. Trước đây việc mô hình tính với điều kiện biên của liên kết cọc nền là chưa chính xác. Bây giờ các phần mềm SACS và GeniE đã có phần tử chịu nén, chịu nhổ nên đã giải quyết được vấn đề này. Tuy nhiên, chỉ có SACS là tính được với sóng, còn GeniE thì không. Bác SteelMan cứ lấy bất cứ một công trình nào đã được mô hình với sóng sau đó thay cọc + nền bằng phần tử chịu nén và chạy thử xem sao.
  8. Wahid
    Wahid New Member
    Sep 8, 2013
    7
    Dear Friends,
    Good Day to all,
    Can I get Sesam Genie 6.4 software.
    Thanks in advance.
    waiting gloriously to get help from my friends.
    Thank you
  9. BigCrab
    442
    23
    Hello Wahid,
    Mày làm nghề gì mà cần dùng phần mềm Sesam Genie vậy? Tao có bộ cài đặt chứ không có thuốc. Sao mày không dùng phần mềm Sacs cũng có tính năng tương tự mà lại có thuốc rồi. Link cho phần mềm Sacs ở đây: http://offshore.vn/threads/207?han-mem-SACS-V-5-3-va-V5-6-Sacs-Software/page5
  10. Wahid
    Wahid New Member
    Sep 8, 2013
    7
    Dear Friend,
    here in my company they were using SACS but now switch to Sesam Genie (Sestra, Xtract, Wajac..)
    I have got the SACS already in that 3Zip files are there but 2 & 3 are not Extractable, I tried a lot.
    That's why SACS is not working..
    Thank you in advance for your help.
  11. hoangtu
    681
    47
    Hi friend,
    The Sacs 5.3 and 5.4 we have crack but not allowance now
    The Sesam we don't have
