Sacs - Câu hỏi thường gặp
Thảo luận trong 'SACS SOFTWARE' bắt đầu bởi admin, 16/9/13.
    SACS Executive eSeminar Attendee Questions
    The SACS Executive eSeminar was hosted in June for users in Americas and Europe, as well as one for our Asia and the Middle East users in August. The following questions and answers are from offerings.
    You can view the recording online at our BeConnected site (Click Here).
    The following are the product-related questions and corresponding answers from the June 20th eSeminar.
    1. Q: What is the significant difference between SACS5.3 and SACS5.4?
      A
      : You can look in the Executive under the SACS News tab and you will see all the major updates and enhancements.
    2. Q: Can we import 3D models from other software into SACS?
      A
      : Yes, Precede can import or export with all Integrated Structure Modeling (ISM;http://communities.bentley.com/prod...wiki/integrated-structural-modeling-home.aspx) compatible solutions like Revit, Tekla, Dlubal, RAM, STAAD. We also can import an sdnf or FEMSYS file.
    3. Q: Any graphic output for the example?
      A
      : Yes. After running the bladed file it created a model file that we can open in Precede.
    4. Q: Is there going to be an option to automatically check in network licenses?
      A: Yes. If you are in automatic mode it will automically check in or checkout the license when you are in or not in use. If in manual mode it will check out the license chosen for two days unless you manually check it back in. These options can be found under the SACS License Explorer tab in the executive.
    5. Q: What is ISM?
      A: Integrated Structural Modeler. (ISM;http://communities.bentley.com/prod...wiki/integrated-structural-modeling-home.aspx)
    6. Q: Is it possible to import from STAAD/Ansys files?
      A: 1. User can export STAAD model into ISM, SACS can import the ISM file.
      2. SACS has a convertor which can be used to convert an ANSYS model into a SACS model.
      Please note that only the structure itself can be converted between STAAD/ANSYS and SACS.
    7. Q: Can we convert Pro-E files to SACS?
      A
      : No
    8. Q: Can I import from Xsteel or PDS?
      A: If the model can be put into an SDNF file or ISM we can import it. Otherwise we cannot import it.
    9. Q: Can a PDMS model be imported into SACS?
      A: If the model can be put into an SDNF file or ISM we can import it. Otherwise we cannot import it. Precede can export to PDMS.
    10. Q: Can PDMS model be imported into SACS?
      A: Yes. In Precede you can choose Import-PDMS.
    11. Q: In the demo folder there are different files types such as ldf. demo 02, pile.demo02, seainp.demo2, sacinp.demo02. Is there's a way I can find out what all of those names mean? (ex. ldf, pile, sacinp, saclst, etc.)
      A: In the Executive under the SACS System Setting you can click on the Program Labels. There is will give the labels for each program name. See below:
      The following are the product-related questions and corresponding answers from the August 7th eSeminar.
    12. Q: What design codes are supported in this software?
      A: SACS supports API, API-LRFD, AISC, AISC-LRFD, NPD, DnV, Eurocode 3, ISO19902, BS and Danish codes.
    13. Q: I'm new to SACS and I want to know how do we export model to other tools like PDMS?ow do you apply the wind load?
      A
      : SACS supports many structural export formats including DXF, ISM and SDNF. SDNF would most likely be best for import to PDMS.
    14. Q: Is SACS 5.4 capable of using Multiple Response Spectra ( e.g., Wind & Wave together) in a time-history analysis?
      A: Yes. In the Analysis generator you can create an Analysis Category of Dynamic and then choose an Analysis Class of Time History Wave, Wind, Force.
    15. Q: Any plans to include AS4100, AS3990 in supported design codes?
      A: We have added support for the Australian AS1170 wind code. Design code support for AS4100 is under consideration for the future depending on user demand.
    16. Q: Can we change any section properties in Line assistant window itself?
      A: Yes, if you edit a SECT section line, you can override the section properties.
    17. Q: Precede manual is not found?
      A: The Precede manual can be loaded from the manuals tab in the Executive.
    18. Q: How do we give input to wind induced fatigue with Spectra?
      A: Enter a range of wind speeds and load cases and stresses for each will be generated.
    19. Q: Do we need to generate transfer function for wind induced fatigue also?
      A: The user inputs a range of wind speeds, SACS calculates the Weibull distribution automatically.
    20. Q: We just completed a design of a flare tower constructed with tubular members using DNV for fatigue check. Is SACS be able to do this?
      A: Yes. This is just the kind of structure that SACS is commonly used for.
    21. Q: More specifically, the current fatigue analysis is based on hot spot stress with stress concentration. can SACS considered this?
      A: Yes.
    22. Q: Does this version include, Mooring line analysis, for offshore vessels?
      A: No. Later this year we will debut the first of our solutions for floating systems. Next year we plan to include mooring capabilities in that.
    23. Q: If we calculate mooring line stiffness separately, how can we apply them to SACS model?
      A: As a user defined external load to the SACS model.
    24. Q: Are you planning to include joint connection design ( tubular section to rolled section) for topside design?
      A:SACS currently has support for local design of tubular to tubular connection. We do plan to include non-tubular to tubular in the future.
    25. Q: How does SACS calculate allowable STRENGTH UC for tubular joints?
      A: Analysis results for each brace at the joint are combined as a percentage of K, X or T&Y joint. For Strength UC, the load part will be 50% of the buckling strength for compression or the yield strength for tension. The capacities will be calculated using the same equations as Load UC except we set the safety factor FS=1.0 in this case.
    Mình cũng có 02 câu hỏi góp vui, mong ae giải giúp
    1/ Tại sao trong một số mô hình người ta lại khai báo density của thép bằng một con số lớn hơn 7.85
    2/ Khi định nghĩa một tiết diện mới vào modeling, khi chạy ra chương trình báo lỗi là tiết diện không tồn tại hoặc thư viện tiết diện không hiểu tiết diện này?
    Xin hỏi AE cách xử lý tình huống này.
    Xin cảm ơn!
  3. Khong
    Ý của mình về việc này là:
    1/ Density với con số lớn hơn 7.85 là density tương đương. Tức là density này không chỉ có thép mà còn có cả những thiết bị phụ khác, ví dụ:
    Trong conductor luôn có các chất của dầu, vữa và nước, do đó khi khai báo density của conductor có hai cách:
    Hoặc là bạn khai báo 7,85 sau đó nhập thêm một loại tải trọng gọi là: content conductor là trọng lượng của các tạp chất trên
    Hoặc là tính trọng lượng của các tạp chất trên và cộng thêm vào con số 7.85 để được density tương đương và nhập vào Sacs.
    Một ví dụ khác cho tiết diện dầm trên topside, ngoài trọng lượng của dầm (density=7.85) còn có cả trọng lượng của tấm plate và hoặc tấm composit đặt trên nó, do đó trọng lượng của bó sẽ bao gồm cả các tấm plate này.
    Ngoài ra cũng có trường hợp người ta khai báo density lớn hơn 7.85 là kể tới hệ số contigency trong thiết kế...
    2/ Xử lý tiết diện này là bạn tính toán ra một loại tiết diện tương đương có đầy đủ các đặc trưng của tiết diện thực cần mô tả rồi khai báo vào modelling ở dạng tiết diên đã có trong thư viện.
    Have fun!
