Một vài câu hỏi khi phỏng vấn - Interview Question
Thảo luận trong 'Chuyên ngành Offshore' bắt đầu bởi hoangtu, 26/5/21.
    Dưới đây là một số câu hỏi bạn có thể gặp trong quá trình phỏng vấn vị trí engineer structural hoặc senior engineer structural cho các công ty trong lĩnh vực dầu khí, oil and gas.
    Interview question:
    Lifting
    1/ The key point, how to perform the Lifting Analysis.
    2/ What is the codes and standard are you following for Lifting Analysis.
    3/ What is differences between lifting in air and in submerged.
    Loadout
    1/ The key point, how to perform the Loadout Analysis.
    2/ What is the codes and standard are you following for Loadout Analysis.
    3/ What is differences between loadout by Trainer and Skid way.
    4/ Can you list out some lesson learn base on your experiences during performed this analysis
    Transportation
    1/ The key point, how to perform the Transport Analysis.
    2/ What is the codes and standard are you following for Transport Analysis.
    3/ What is differences between transportation by Moses and Sacs.
    4/ You may know that, we always want to reduce the numbers of seafasterning for save time offshore work, do you have any idea to minimize the number of seafasterning members?
    WCR
    1/ What is purpose of the WCR, which one you wish to show in this report?
    2/ What is the codes and standard are you following and do TEN have any specification or checklist?
    3/ How you manage the discipline input weight? Which software use?
    4/ The contingency factor should be based on the stage of project, during the FEED, how much you would be applied? (secondary steel 20% or more, plate 40% or more, equipment 30% or more…)
    5/ Can you list out some lesson learn based on your experiences during performed this report.
    MTO
    1/ What is software are you use to perform the MTO report?
    2/ Can you prepare the TBE or Spect for steel material?
    Misc
    1/ What is software are you use to perform the report?
    2/ Do you family with FEA software (Ansys, abaqus…)?
