Caesar II and Cadworx 2014!
Thảo luận trong 'Những Phần Mềm Khác' bắt đầu bởi piping, 20/1/14.
  1. piping
    piping Member
    Bác nào quan tâm đến hai phần mềm trên thì ghé vô lavteam.net để lấy link download nhé.
    Cheers!
    Intergraph CADWorx (Plant, P&ID, Equipment, IP, SpecEditor) 2014 build 23.07.2013
    "Intergraph CADWorx Plant Design Suite is an integrated, complete AutoCAD-based software series for plant design that provides intelligent drawing and database connectivity, advanced levels of automation, and easy-to-use drafting tools. The comprehensive series of design tools includes structural steel, equipment, process and instrument diagrams, and design review, plus automatic isometrics and bills of material. CADWorx is quick and easy to set up and use, so you can start designing right away. The bi-directional links between CADWorx and analysis programs for pipes and vessels enable designers and engineers to easily share information while keeping the drawings, models, and related information continuously synchronized as changes are made. And, the fast processing and highly refined user-interface features in CADWorx empower users to work efficiently together, even on large models. Since its introduction, CADWorx has revolutionized the plant design industry with its ease of use, flexibility, interconnectivity, and scalability.
    link:http://files.lavteam.net/leech?cat=...=Intergraph.CADWorx.2014.build.23.07.2013.rar
    Intergraph CAESAR II 2013 R1 v6.10.00.0028 build 121130
    "Ensuring your plant’s piping systems adhere to international codes and standards plays an integral role in keeping your plant operational. Intergraph CAESAR II software makes it easy to input and display all the data needed to accurately define a piping system analysis model. It evaluates the structural responses and stresses of your piping systems to international codes and standards, and enables you to access and modify, if necessary, input element by element or globally. As pipe flexibility and stress analysis software, CAESAR II makes quick work of developing analysis models while clearly indicating areas of concern via color-coded stress models and animated displacements for any stress load case. Included are tools and wizards to help you create expansion loops or view plant models, removing the guesswork from producing accurate analysis and recommending practical design changes."part1:
    http://files.lavteam.net/leech?cat=....2013.R1.v6.10.00.0028.build.121130.part1.rar
    part2:
    http://files.lavteam.net/leech?cat=....2013.R1.v6.10.00.0028.build.121130.part2.rar
    Source : www.lavteam.net
    Chỉnh sửa cuối: 25/1/14
  2. thanhtuan
    thanhtuan New Member
    Cái này có crack đầy đủ chưa Bro ???
  3. piping
    piping Member
    có đầy đủ hết Bro, nhưng hơi kho cr... đọc kỹ hướng dẫn trước khi cài. Good luck
  4. nucuoi
    nucuoi New Member
    link bi die roi ban oi (sorry unikey cua minh bi hong)
  5. piping
    piping Member
    Không biết bạn cần phần mềm nào Cadworx hay Caesar ii, tôi có thể upload lên 4shared cho bạn download. Tôi vừa xem link lại bên lavteam thì vẫn ok nhưng phải click link từ lavteam thì không báo lỗi nếu click trực tiếp từ đây thì bị lỗi.
  6. nucuoi
    nucuoi New Member
    @piping: mình cần source của Caesar II, vào LAVteam nó toàn ra tiếng nga, đọc ko hiểu, nếu có link 4shared thì tốt quá, thanks bạn
  7. piping
    piping Member
    @nucuoi: bác cố gắng đợi một hai ngày nhé, hiện tại mình đang tai lên 4shared, nhưng dung lượng hơi lớn (>1GB) nên hơi lâu.Mình đã dùng winrar chia làm 16 phần đây là phần thứ nhất mình mới up lên.
    http://www.4shared.com/rar/GfXVhCH7ce/cae_2013__1_.html
    c
    ó thể tới sáng mai mình sẽ đưa link đầy đủ của 15 phần còn lại(nếu đường truyền internet nhà mình không gặp sự cố)
    Chỉnh sửa cuối: 7/4/14
  8. piping
    piping Member
  9. nucuoi
    nucuoi New Member
    thanks bro, link down rất nhanh
  10. ksctm
    ksctm Member
    Đây là bản x32 hay x64 thế ạ? Đã có xxx chứa bác nhỉ ?
    Many thanks
  11. piping
    piping Member
    Mình đã thử trên win7 32-64bit đều đc hết. Bản này hơi khó crack nó đòi hỏi phải có mạng. Các bác nên tạo một mạng ảo trước khi cài nó.nếu bác đang sử dụng mạng LAN thì không cần. Còn sử dụng mạng wifi thì phải tạo mạng ảo, vì ở VN mình dùng địa chỉ IP động, phần mềm mỗi lần khởi động sẽ kiểm tra địa chỉ ip của máy tính cài đặt. Thuốc và Serial,cùng file hướng dẫn đầy đủ. Các bác đọc kỹ file hướng dẫn nhé và nhớ phải tạo mạng ảo và thiết lập nó là ưu tiên một nếu máy connect bằng wifi.
  12. duongvan
    duongvan New Member
    Cadworx 2014
    Em đang cần phần mềm CADWORX để vẽ sau đó Import vào CAESAR II. Bác xem lại đường link cho em down với nhé. Trân trọng cảm ơn bác nhiều!!!
    Chỉnh sửa cuối: 3/5/14
  13. piping
    piping Member
    @duongvan
    Tạm thời tôi không thể upload lên 4shared được, bạn chịu khó vào đây đăng ký thành viên để lấy link tải về, http://www.egpet.net/vb/threads/72101-Cw2014-with-serial ( nếu không được thì ba tuần nữa tôi sẽ up cho bạn sau)
  14. duongvan
    duongvan New Member
    Vâng cảm ơn bác! Bác up lên giúp em với nhé, tình hình là em không tải về được từ đường dẫn kia.
    Chỉnh sửa cuối: 5/5/14
  15. piping
    piping Member
  16. duongvan
    duongvan New Member
    Thanks bác nhiều ạh!!!!
  17. yukida
    yukida New Member
    Sinh Viên
    Tp Hồ Chí Minh
  18. Pipeline
    Pipeline New Member
    Minh co bo cai roi
    nhung ma crack thi chua co, ban nao giup minh voi
  19. yukida
    yukida New Member
    Sinh Viên
    Tp Hồ Chí Minh
    link mình chia sẽ có đủ C-rack luôn đấy
  20. Pipeline
    Pipeline New Member
    ban thu xem lai ho minh voi xem linh died chua
