Australia Standard Collection
Thảo luận trong 'Tiêu chuẩn & Qui phạm – Code and Standard' bắt đầu bởi ch3coohminh, 13/6/15.
  1. ch3coohminh
    Share cho anh em nào cần.
    Rất nhiều TCVN đều có nguồn gốc từ AU Std.
    http://www.fshare.vn/file/HHPUT9KT61GU
    as 1065 - ultrasonic testing of c.s forgings.pdf
    as 1065-1988 non-destructive testing - ultrasonic testing of.pdf
    AS 1100 Part 201_AMD1.PDF
    AS 1100 Part 301 Supplement 1 - Architectural Drawings.PDF
    AS 1100 Part 401 - Engineering Survey Drawing.PDF
    AS 1100 Part 501 - Structural Engineering Drawing.pdf
    AS 1101-2 Ventilation Symbols in Ships.pdf
    AS 1101-6 Process Measurement & Control Symbols.pdf
    AS 1138 - Thimbals for Wire Rope.pdf
    AS 1163 - Hollow Sections for Structural Steel.pdf
    AS 1167.1-1993 Welding and brazing - Filler metals - Filler .pdf
    AS 1170.2-1989 Amdt 1-1991 .pdf
    AS 1170.2-1989 Amdt 3-1993 .pdf
    AS 1171-1998 NDT - MPI.pdf
    AS 1200-1994 PRESSURE EQUIPMENT.PDF
    AS 1200-2000 Pressure Equipment.pdf
    AS 1210 Pressure Vessels.pdf
    AS 1210 Supplement 1 - Unfired Pressure Vessels - Advanced D.pdf
    AS 1210 Supplement 1 - Unfired Pressure Vessels - Advanced D_2.pdf
    AS 1210 Supplement 2 - Stainless Steel for Vessels.pdf
    AS 1228-2006 Pressure equipment—Boilers.pdf
    AS 1250 - Steel Structures Code.pdf
    AS 1252 - High Strength Steel Bolts .pdf
    as 1271 safety valves & guages.pdf
    AS 1271-Draft 02299.pdf
    AS 1289.0-2000 Methods of testing soils for engineering purp.pdf
    AS 1319-1994 Safety Signs.pdf
    AS 1345-1995 Contents of Pipes.pdf
    as 1391 - tensile strength of steels.pdf
    AS 1400-1 Environmental Management Systems.pdf
    AS 1403 - Rotating Steel Shafts.pdf
    AS 1538 - Cold Rolled Steel for Structures.pdf
    AS 1548 - Steel Plate for Pressure Equipment.pdf
    AS 1554 Part 1 1995 - Welding of Steel.pdf
    AS 1554 Part 1 2000.pdf
    AS 1554 Part 2 - Stud Welding.pdf
    as 1554 part 3 - welding reinforcing steel.pdf
    AS 1554 Part 3 Draft00266.pdf
    as 1554 part 4 - welding high strength quenched steel.pdf
    AS 1554 Part 5 - Welding of Structures with High Fatigue Loa.pdf
    AS 1554 Part 6 - Structural Welding of Stainless Steels.pdf
    as 1576.1 scaffolding general requirements.pdf
    as 1576.2 scaffolding couplers & accessories.pdf
    as 1576.3 scaffolding prefab & tube.pdf
    as 1576.4 scaffolding suspended scaf.pdf
    as 1576.5 scaffolding prefab splitheads & trestles.pdf
    as 1576.6 scaffolding metal tube&coupler.pdf
    AS 1594 - Hot Rolled Flat Steels.pdf
    AS 1627-0 1997.pdf
    AS 1627-4 1989.pdf
    AS 1627-9 ISO 8504.pdf
    as 1657 fixed platforms walkways.pdf
    as 1674.1 safety in welding & allied processe fire precautio.pdf
    as 1674.2 safety in welding & allied processe electrical.pdf
    as 1692 tanks for flammable & combustible liquids.pdf
    as 1692-1989 tanks flammable liquids.pdf
    as 1710 - ultrasonic testing of plate.pdf
    AS 1715 Selection Use Maint of Respiratory Protective Device.pdf
    AS 1716 AMDT 1996 Respiratory Protective Devices.pdf
    AS 1716 Respiratory Protective Devices.pdf
    AS 1720-1988 Part 1 - Timber Structures.pdf
    AS 1720-1997 Timber Structures Code Part 1 - Design Methods.pdf
    as 1726 geotechnical site investigation.pdf
    AS 1726-1993 Geotech site investigations.pdf
    as 1755-1986 conveyors - design & fabrication.pdf
    as 1755-2000 conveyors safety requirements.pdf
    AS 1768 Lightning Protection.pdf
    AS 1796.pdf
    as 1800-1998 occupational protective helmets selection care .pdf
    as 1801 amdt 1999 occupational protective helmets.pdf
    as 1801 occupational protective helmets.pdf
    as 1817 - vickers hardness.pdf
    AS 1841.1 AMDT 2001 Fire Extinguishers.pdf
    AS 1841.1 Fire Extinguishers.pdf
    as 1885 1 supp 1-1991 measurement of occupational health and.pdf
    as 1885 1-1990 occupational health and safety performance.pdf
    AS 1885 B-1976 Register of work injuries.pdf
    AS 1885 C-1976 Register of work injuries - modified -.pdf
    AS 1891 3 Industrial Fall Arrest Devices.pdf
    as 1921-1976 airconditioning and ventilation in ships cabins.pdf
    as 1921-1976 amdt 1-1984 airconditioning and ventilation in .pdf
    as 1929-1981 non-destructive testing - glossary of terms.pdf
    AS 1940-1993 Storage - Handling.pdf
    as 1958 submarine pipeline code.pdf
    as 1978 pipelines - field pressure testing.pdf
    AS 2030-1.pdf
    AS 2033 - Installation of Polyethylene Pressure Pipe.pdf
    as 2038 - intergranular corrosion in austenetic s.s...pdf
    as 2062 - penetrant testing.pdf
    as 2083 - ultrasonic testing - use of calibration blocks.pdf
    AS 2084 - Eddy Current Testing of Tubes.pdf
    as 2129 - flanges for pipes, valves and fittings.pdf
    as 2177 part 1 - radiography of welded joints.pdf
    as 2177.1-1994 non-destructive testing - radiography of weld.pdf
    as 2177.2-1982 radiography of welded butt joints in metal - .pdf
    as 2207-1994 non-destructive testing - ultrasonic testing of.pdf
    as 2210.1 occupational protective footware - selection care .pdf
    as 2210.3 occupational protective footware - safety footwear.pdf
    AS 2211 - 1 Supp1-1999 Laser Safety - Equipment Classicicati.pdf
    AS 2211 Laser Safety - Equipment Classicication.pdf
    as 2239 - galvanic anodes for cathodic protection.pdf
    as 2243 - 2-1997 safety in laboratories chemical aspects.pdf
    as 2243 - 10-1993 safety in laboratories storage of chems.pdf
    as 2243-1997 safety in laboratories general.pdf
    as 2291 - methods to establish tensile strength at elevated .pdf
    as 2299 - 1 occupational diving-std operational practice.pdf
    AS 2346 - Elongation of material.pdf
    AS 2382.pdf
    as 2397 safe use of lasers - building & construction industr.pdf
    AS 2403 - Measurement of Plastic Strain.pdf
    AS 2430 Part 3-5 - Hazadous Areas in Process Plants.pdf
    as 2430-1 classification of hazardous areas.pdf
    as 2444 - 4 portable fire extinguishers - selection & locati.pdf
    as 2444-4 amdt 1 portable fire extinguishers - selection & l.pdf
    as 2452 part 3 - ultrasonic testing - thickness measurement.pdf
    as 2550 - 1 cranes safe use general req.pdf
    as 2550 - 5 cranes safe use mobile & vehicle.pdf
    as 2550 - 6 cranes safe use - guided st & ret app.pdf
    as 2550 - 10 cranes safe use - ewps.pdf
    AS 2726 - 1-1995 Chainsaws Safety Requirements.pdf
    AS 2741.pdf
    AS 2741_AMD1.pdf
    AS 2759 - Applications For Wire Rope.pdf
    as 2780 - refractory glossary of terms.pdf
    as 2815 - 1-1992 training and certification of occupational .pdf
    as 2815 - 2-1992 training and certification of occupational .pdf
    as 2815 - 3-1992 training and certification of occupational .pdf
    as 2815 - 4-1992 training and certification of occupational .pdf
    AS 2832 - 2 CP Draft.pdf
    as 2832 part 1 - cathodic protection - pipes and cables.pdf
    as 2832 part 3 - cathodic protection - immersed stuctures.pdf
    as 2832 part 4 - cathodic protection - internal surfaces.pdf
    AS 2832-2 CP of Metals.pdf
    as 2865 safe work in confined space.pdf
    as 2885-1-1997 amdt 1-2001 pipelines - gas and liquid petro.pdf
    as 2885-1-1997 pipelines - gas and liquid petroleum - desig.pdf
    as 2885-2 1995 pipelines gas & liquid - welding.pdf
    as 2885-2 amdt 1 1996 pipelines gas & liquid - welding.pdf
    AS 2885-2 Draft01281.pdf
    as 2885-2-2002 pipelines - gas and liquid petroleum - weldin.pdf
    as 2885-3-2001 pipelines - gas and liquid petroleum - operat.pdf
    AS 2980 WELDER QUALIFICATIONS FOR WELDING STEEL STRUCTURES.PDF
    as 2985 workplace atmospheres resp dust.pdf
    as 3000 - 2000 electrical intallations wiring rules.pdf
    AS 3012 Electrical Intallations Construction & Demolishion s.pdf
    AS 3545 - Welding Positions.pdf
    AS 3569 - Steel Wire Ropes.pdf
    AS 3597 - Plate for Structural and Pressure.pdf
    AS 3600 - Concrete Structures.pdf
    AS 3600 Supplement 1 - Concrete Structures.pdf
    as 3610 formwork for concrete.pdf
    as 3610-1995 concrete formwork.pdf
    AS 3637 Part 1 - Underground Mining Equipment - General Requ.pdf
    AS 3637 Part 2 - Underground Mining Suspension Equipment - H.pdf
    AS 3637 Part 3 - Underground Mining Equipment- Rope Cappings.pdf
    AS 3637 Part 4 - Underground Mining Equipment- Drawbars.pdf
    AS 3637 Part 5 - Underground Mining Equipment- Rope Swivels .pdf
    AS 3637 Part 6 - Underground Mining Equipment- Shckels & Cha.pdf
    as 3640 workplace atmosheres - inspirable dust.pdf
    AS 3751 - Underground Slope Mining Equipment.pdf
    as 3765.1 clothing for hazardous chemicals.pdf
    as 3765.2 clothing for hazardous chemicals - limited protect.pdf
    AS 3785 Part 1 - Underground Shaft Mining Equipment.pdf
    AS 3785 Part 2 - Underground Shaft Mining Equipment.pdf
    AS 3785 Part 3 - Underground Shaft Mining Equipment.pdf
    AS 3785 Part 4 - Underground Shaft Mining Equipment.pdf
    AS 3785 Part 5 - Underground Shaft Mining Equipment.pdf
    AS 3785 Part 6 - Underground Shaft Mining Equipment.pdf
    AS 3785 Part 7 - Underground Shaft Mining Equipment.pdf
    AS 3788-1996.PDF
    AS 3788-2001 Pressure Equipment Inservice Inspection.pdf
    AS 3857 - Heat Exchanger Tube Plate Design.pdf
    AS 3873-1995.PDF
    AS 3873-2001 Pressure Equipment - Operation & Maint.pdf
    AS 3892 Draft262.pdf
    as 3894.0-2002 site testing of protective coatings - introdu.pdf
    as 3894.1-2002 site testing of protective coatings - non-con.pdf
    as 3894.2-2002 site testing of protective coatings - non-con.pdf
    as 3894.3-2002 site testing of protective coatings - determi.pdf
    AS 3894.4-2002 Site testing of protective coatings - Assessm.pdf
    as 3894.5-2002 site testing of protective coatings - determi.pdf
    as 3894.6-2002 site testing of protective coatings - determi.pdf
    as 3894.7-2002 site testing of protective coatings - determi.pdf
    as 3894.8-2002 site testing of protective coatings - visual .pdf
    as 3894.10-2002 site testing of protective coatings - inspec.pdf
    as 3894.11-2002 site testing of protective coatings - equipm.pdf
    as 3894.12-2002 site testing of protective coatings - inspec.pdf
    as 3894.13-2002 site testing of protective coatings - inspec.pdf
    as 3894.14-2002 site testing of protective coatings - inspec.pdf
    AS 3920-1 Draft081.pdf
    AS 3931 Risk Analysis-Application Guide.pdf
    AS 3961 LNG Storage & Handling.pdf
    AS 3961-1991 LNG Storage.pdf
    as 3978-1991 non-destructive testing - visual inspection of .pdf
    AS 3990 - Structural Steel For Mechanical Engineering.pdf
    as 3992 - welding and brazing qualifications.pdf
    AS 3992 Draft Amnd1.pdf
    as 3998-2002 non-destructive testing - qualification and cer.pdf
    AS 4037 - Pressure Equipment - Examination and Testing.pdf
    AS 4041 - Pressure Piping.pdf
    AS 4087.pdf
    AS 4100 1990 - Steel Structures.pdf
    AS 4100 1998.pdf
    AS 4100 1999 supp 1.pdf
    AS 4343.pdf
    AS 4360-1999 Risk Management.pdf
    as 4458 - manufacture of pressure vessels.pdf
    as 4576 1995 guidelines for scaffolding.pdf
    as 4749-2001 non-destructive testing - terminology of and ab.pdf
    AS 4801 H&S Management Systems.pdf
    AS 4804 draft051.pdf
    AS 4804 H&S Management Systems Guidelines.pdf
    as 24301 classification of hazardous areas.pdf
    as 24444 amdt 1 portable fire extinguishers - selection & lo.pdf
    as 24444 portable fire extinguishers - selection & location.pdf
    AS B202-1962 Acme screw threads.pdf
    AS ISO 15489.1-2002 Records management - General.pdf
    AS ISO 15489.2-2002 Records management - Guidelines.pdf
    as nzs 1167.2-1999 welding and brazing - filler metals - fil.pdf
    as nzs 2299.1 supp 1-1999 occupational diving operations - s.pdf
    as nzs 2299.1-1999 occupational diving operations - standard.pdf
    as nzs 2885.5-2002 pipelines-gas and liquid petroleum - fiel.pdf
    as nzs 3992-1998 amdt 1-2000 pressure equipment - welding an.pdf
    as nzs 3992-1998 pressure equipment - welding and brazing qu.pdf
    as nzs 4360-1999 risk management.pdf
    DR-AS-1657-Fixed-platforms-walkways-stairways-and-ladders-Design-construction-and-installation.pdf
    dingzero and danghungapd like this.
  2. dingzero
    dingzero New Member
    Hi a ch3coohminh,
    A update lại link được không ạ? E cần 1 số tiêu chuẩn trong collection này của a :D
    toanndvt thích bài này.
