TEMA Type: AES stacked unit, ID 1200mm, 6 passes, 910 tubes 1″ OD plain x 6096mm length, square tube pattern, CS shellside, A387 Gr.5 Cl.2 tubeside, DP: 37 / 24.7 kg/cm2 + HV, DT: 260 / 365 0C, expanded+strength welded tube to tubesheet joint https://drive.google.com/open?id=0B2ttwknJB4dRQmN6YUYzYTVfT00
A video clip show how to use Aspen EDR for thermal design of shell and tube heat exchanger. In this sample, a feed / stripper bottoms exchanger type BEU, duty 10.61 MW, carbon steel, design pressure: 10/FV kg/cm2 for shell side, 11/FV kg/cm2 for tube side; design temperature: -10/205 (S), -10/240 (T) Celsius degree, CA: 3 was modeled. Here is the link to video clip: https://drive.google.com/open?id=0B2ttwknJB4dRcXBCSTJQUFlHeVk Please like and share if you find it useful. enjoy ! Thanks, Blog: https://wordpress.com/post/thietbiaplucblog.wordpress.com/106 Facebook: cac ban search thietbiapluc nha, minh hay post bai o day
