Asme 2015
Thảo luận trong 'Tiêu chuẩn & Qui phạm – Code and Standard' bắt đầu bởi ch3coohminh, 14/8/15.
  1. ch3coohminh
    Hàng mới ra lò cách đây vài hôm.
    Down không cần hỏi.
    (Update thêm 1 số tiêu chuẩn)
    https://www.fshare.vn/file/P3ZH4UOJCW7Z
    ASME BPVC Section I-2015_Rules for Construction of Power Boilers.pdf
    ASME BPVC Section IIA-2-2015.pdf
    ASME BPVC Section IIA-2015.pdf
    ASME BPVC Section IIB-2015.pdf
    ASME BPVC Section IIC-2015.pdf
    ASME BPVC Section IID-M-2015.pdf
    ASME BPVC Section IV-2015_Rules for Construction of Heating Boilers.pdf
    ASME BPVC Section IX-2015_Welding, Brazing, and Fusing Qualifications.pdf
    ASME BPVC Section V-2015_Nondestructive Examination.pdf
    ASME BPVC Section VI-2015_Recommended Rules for the Care and Operation of Heating Boilers.pdf
    ASME BPVC Section VII-2015_Recommended Guidelines for the Care of Power Boilers.pdf
    ASME BPVC Section VIII-2015_Rules for Construction of Pressure Vessels-Division 1.pdf
    ASME BPVC Section VIII-2015_Rules for Construction of Pressure Vessels-Division 3-Alternative Rules for Construction of High Pressure Vessels.pdf
    ASME BPVC Section X-2015_Fiber-Reinforced Plastic Pressure Vessels-new.pdf
    ASME BPVC Section XI -2015 - Rules for Inservice Inspection of Nuclear Power Plant Components.pdf
    ASME BPVC Section XII-2015_Rules for Construction and Continued Service of Transport TanksBPVC-XII_2015.pdf
    Chỉnh sửa cuối: 18/8/15
  2. toanndvt
    toanndvt New Member
    Cám ơn anh nhiều quá! Khi nào có BPVC 2017 thì chia sẻ em với nhé!
