Sự bùng nổ của Subsea trong thời gian tới
Thảo luận trong 'Tension Leg Platform, Buoy – Type Platform' bắt đầu bởi SteelMan, 5/12/13.
  1. SteelMan
    The $103 billion annual increase in spending on Subsea Processing Systems
    Right now only about 30% of oil and gas extracted in the world is from off-shore oil & gas production.
    Most of that off-shore production is from shallow water wells. Only 9% of that oil and gas is being recovered from deep water wells.
    And that is changing fast.
    One of the biggest trends in the oil & gas industry is best described as: “Deeper, deeper, deeper.
    Over the next 15 to 20 years the industry expects off-shore oil and gas production will equal on-shore production. Think about that: this is like getting into the traditional oil industry back before all of the biggest fields were put into production!
    Most on-shore fields are mature fields. But the ocean holds enormous oil & gas fields like the Shenandoah Basin in the Gulf of Mexico that looks like it could hold 15 BILLION barrels of oil or the Mad Dog Field holding an estimated 4 billion barrels.
    That’s why the oil & gas industry is betting its future on deep water drilling.
    And it’s barely been tapped. The industry currently spends $27 BILLION a year on subsea facilities - for wells at depths of 7,000 feet or more. That number is set to grow almost FIVE TIMES over to $130 BILLION in 2020.
    Right now is the time for smart investors to get in front of this $100 billion a year ramp up in spending on subsea facilities.
    Where is that money going to be spent?
    First, let’s look at what subsea processing is.
    Deep sea wells are drilled by a moveable rig and the extracted oil and natural gas is transported by riser or undersea pipeline to a nearby production platform.
    Subsea systems, used at depths of 7,000 feet or more, don’t drill; they extract and transport the oil or gas.
    Unlike traditional shallow water drilling, subsea systems actually process oil & gas on the sea floor.
    These systems can separate unwanted elements from the oil & gas right on the seafloor: remove or re-inject water into wells, boost well fluids, remove sand and sediment, separate gas & liquid.
    These are all activities that USED to have to happen above water which made deep-sea processing so expensive.
    Basically subsea systems cut out an entire layer of traditional production simply by doing everything down on the seafloor.
    That translates into lower production costs so it saves money and increases the profit margin on each well.
    PLUS; subsea production also allows you to use a single platform to service multiple wells. In other words, it saves money while increasing production - a double winner for the industry.
    So it’s no wonder the industry is looking to expand from $27 billion a year investment into subsea processing to $130 billion in 2020.
    In order to fully develop subsea fields the industry needs NEW equipment that makes this work: from specialized drill rigs, deep sea power systems and more.
    That’s what this $100 billion a year increase is going to be spent on first. So in the logical sequence of drilling in the deep sea this new technology is where investors need to look right now.
    As investors we want to get in front of that $100 billion increase in spending. Clearly, the companies who will be benefiting from this massive new investment are the ones that interest investors.
    Who will get the money?
  2. NoName
    Technip và GE cũng đang đẩy mạnh lĩnh vực này trong khi "miếng bánh fixed platform" đang nhỏ dần. Không biết có công ty dầu khi Viet Nam nào đã chuẩn "đi tắt, đón đầu" không nhỉ????
  3. DocCoCauBai
    Loại kết cấu này chỉ phức tạp phần công nghệ và thi công lắp đặt biển
    còn kết câu thì không vấn đề, rất simple
    Mà mảng công nghệ và thi công biển chi có mỗi vsp là thể hiện được độ phũ và vị thế bá đạo trong làng CTB Việt Nam
  4. SteelMan
    Phần tính toán thi công công trình biển này cũng khá phức tạp, đặc biệt là phân tích cẩu động trong quá trình lắp đặt (theo bộ Tiêu chuẩn Marine Operation của DNV) ngoài ra anh em cũng có rất ít kinh nghiệm về mạng này, không biết VPS có đủ khả năng tính toán và thi công không nhỉ?
  5. BigCrab
    Thế giới người ta làm subsea mà không thấy giàn đâu (xem ảnh bài trên). Ở xứ mình do đi tắt đón đầu nên làm subsea toàn dính với jacket. Thế cho nên các bác không phải lo nữa đâu. Công nghệ subsea của mình đã tiến xa hơn thế giới một bước rồi đó.
  6. nucuoi
    nucuoi New Member
    mình xin chia sẽ 1 số khó khăn của dự án subsea như sau:
    - Spec, requirement cao chót vót + tiến độ rất hẹp + số lượng, khối lượng vật tư nhỏ ở tất cả các khâu EPCI. bác nào đọc PMBOK thì đủ hiểu là với 3 ràng buộc này thì rủi ro dự án fail là rất cao. Nó khó gấp 2, 3 lần so với làm các dự án WHP, CPP mặc dù giá trị dự án của nó rất nhỏ (mình cũng đã làm các dự án WHP, CPP rồi nên mới nhận xét vậy).
    - khâu nào cũng khó cả từ E-P-C-I đặc biệt là các LLI và T&I. Làm chủ được các LLI và T&I thì mới nói là thực hiện đc.
    Engineering: chuyên về subsea, tính toán flow assurance,...
    LLI tiêu biểu: Wet tree (khác dry tree của WHP), subsea control system, subsea valve... mấy loại này rất ít vendor trên thế giới làm
    T&I: SAT, ROV, diver, tàu DP3,... nói chung là 1 team tàu, thiết bị siêu đắt tiền chuyên cho công tác subsea (ko cần tàu to nhé). cái này em cá là ở vn chưa có nhà thầu nào đủ lực làm đc kể cả VSP
  7. BigCrab
    Câu trả lời quá đầy đủ để chúng ta chuyển sang vấn đề khác ?@_@?
  8. jacket
    jacket Member
    Theo em thì quá chuẩn - ko còn gì để nói - closed topic ngay và luôn.
  9. Khong
  10. Long Le Dinh
    Long Le Dinh Guest
    Các mems đang nhìn vào cái subsea production manifold như trong bài mà ad đã post mà chưa thấy bao quát hết. Một câu hỏi đơn giản là làm thế nào để đưa được dầu/khí lên surface? Trả lời được câu hỏi này chúng ta sẽ bàn tiếp.
