Hàng mới ra lò cách đây vài hôm. Down không cần hỏi. (Update thêm 1 số tiêu chuẩn) https://www.fshare.vn/file/P3ZH4UOJCW7Z ASME BPVC Section I-2015_Rules for Construction of Power Boilers.pdf ASME BPVC Section IIA-2-2015.pdf ASME BPVC Section IIA-2015.pdf ASME BPVC Section IIB-2015.pdf ASME BPVC Section IIC-2015.pdf ASME BPVC Section IID-M-2015.pdf ASME BPVC Section IV-2015_Rules for Construction of Heating Boilers.pdf ASME BPVC Section IX-2015_Welding, Brazing, and Fusing Qualifications.pdf ASME BPVC Section V-2015_Nondestructive Examination.pdf ASME BPVC Section VI-2015_Recommended Rules for the Care and Operation of Heating Boilers.pdf ASME BPVC Section VII-2015_Recommended Guidelines for the Care of Power Boilers.pdf ASME BPVC Section VIII-2015_Rules for Construction of Pressure Vessels-Division 1.pdf ASME BPVC Section VIII-2015_Rules for Construction of Pressure Vessels-Division 3-Alternative Rules for Construction of High Pressure Vessels.pdf ASME BPVC Section X-2015_Fiber-Reinforced Plastic Pressure Vessels-new.pdf ASME BPVC Section XI -2015 - Rules for Inservice Inspection of Nuclear Power Plant Components.pdf ASME BPVC Section XII-2015_Rules for Construction and Continued Service of Transport TanksBPVC-XII_2015.pdf
