tài liệu về sức chịu tải của cọc trong công trình biển( GRLWeap-Wave Equation)_P2
Thảo luận trong 'Phần Mềm Phân Tích Địa Chất' bắt đầu bởi vuong53cb2, 18/5/12.
  1. vuong53cb2
  2. hieudk53
    hieudk53 New Member
    19-1 An unreinforced concrete pipe has a wall
    thickness of t = 3 inches, ID = 36 inches, and length
    of L = 11 ft. A 12-kip dual-wheel load passes over
    midspan. Soil cover is negligible. What is the water
    pressure inside the pipe at failure if the soil has been
    washed out from around the pipe leaving it simply
    supported on the ends? The joints are gasketed.
    Unit weight of concrete is 144 pcf, unit weight of
    water is 62.4 pcf, and strengths of the concrete are
    2 ksi in tension and 12 ksi in compression.
    19-2 What is the maximum tangential stress in a
    thick-wall, closed-end cylinder that has a small tap
    in it, if OD = 1.4(ID)?
    19-3 A polyethylene pipe is to be installed under a
    river. A tunnel, slightly larger than the pipe, is
    directionally drilled under the river and driller's mud
    is left in the tunnel to prevent collapse of the tunnel
    until the pipe can be pulled through. As the pipe is
    being pulled into place, the driller's mud is replaced
    by grout. What is the maximum stress in the wall of
    a polyethylene pipe subjected to the external
    hydrostatic pressure of grout with unit weight 95 pcf,
    and depth of 80 ft? The pipe is empty such that
    pressure inside is atmospheric.DR = 9.5 = OD/t for this thick-wall pipe. Neglect
    longitudinal force during the pull
    (s t = 280 psi)
